Thanx for the input Tim. What kind of drain do you use? easy access? and yes, lake water only.
Bill, i sent you a pm. engines in great shape, maybe some pitting in #8, i was getting water into 1 & 2, i believe from the inlet pressure, only when on my trailer, didn't happen in the delta last time out. Its a 10.25 compression engine supposedly the same one used in the 442's from what i was told from Jack Keaton (boats builder/namesake) and the head engineer at Berkeley Pump Com.
Mike
