I didn’t get out in the garage Saturday because it rained two inches and I was chicken to open up the door with all the bare metal. I really need to get some primer on this thing soon !!!
I couldn’t decide whether to start on the Vintage Air install or the T-56 mock-up. Since the T-56 box was bigger and harder to keep moving around I decided to start there. I had been looking at the Hurst mount for a while and finally ordered one through AMP Performance in Phoenix. It seems well built !
My friend at work had this plastic mock-up sitting around and loaned it to me. Hopefully I wont break it in too many places. Also shown are the Dirty Dingo slider mounts. They seem well made, and are local so I decided to give them a try.
Also if you use one of these you will have to drill a hole to clear the input shaft because it is flat in back. The piece I drilled out looks like this and I used a 1.5 inch hole saw.
I supported the transmission and then hung the plastic mockup from it to prevent putting too much pressure on the plastic.
Then I installed the Dingo sliders and my original mounts on the plastic block and gradually lowered it in place. This is as far back as the setup will go but I think it looks about right.
Here is a view from below showing how the Hurst mount curves back to meet the T-56 tail mount. Also you can see I added another strap under the transmission case to keep a little pressure off of the plastic engine mock-up. It actually seems pretty strong, but I thought best to support it a little bit more.
I probably need to look into rear mounts. This poly mount used the two small inside holes. I need to figure out if there is a mount that will use the two large outside holes because it will be much stronger. That may be for the factory clamshell mount which I would really like to use to cut down on vibration. I will check to see if that will work with the Hurst rear mount.
I removed the shifter and taped up the hole before rolling it back. Overall, it doesn't fit that bad. Nothing touches on the top but it won’t go all the way back due to interference with the widest part of the transmission case. I still need to check that the engine is the proper down angle. It looks a little too far down which means raising it will put things even closer to the floor. I am not sure how much I will raise the tunnel yet, but somewhere around 1.5 inches looks about right so far.
One more view where I left if for tonight.
