Its coming out gorgeous! Where does the DSE/Vintage air A/C bracket bolt up to under the dash, any pictures of it? That tank should supply plenty of fuel. Nice work!
I wish i had some pics of the evaporator bracket bolted up under the dash to show you but i can't find any! It does however bolt to a dash support bracket in the centre of the dash as well as to an existing hole above the pass side kick panel. For how tight everything gets up there i would recommend it to ease trying to fab something up. ( hope that made sense ? )
Ok it has been awhile but i can finally get back to the updates! After the last few pics all the mockup power train came back out and the completed 427 was finally put into the car!
Once the 78mm precision turbo came in I did have to modify the housing as it was bigger than our mock up. We got it tucked in and fit right where it needs to be but its tight around the waste gate and i had to adjust the thermostat housing a "pinch" lol . Once that was done i could finally finish all the waste gate and exhaust on the pass side!
