Old 04-14-2016, 12:01 PM
gerno's Avatar
gerno gerno is offline
There. You convinced yourself. Go dry sump. See, that wasn't so bad.
Pretty sure you are trying to justify your build.......
Old 04-14-2016, 12:04 PM
That ship sailed a long time ago.
Even his own builder is posting dry sump tank locations...
Old 04-14-2016, 12:32 PM
DB Z28 DB Z28 is offline
I,m in the same boat also looking where to place the dry sump tank. Looked at the firewall area and it it seem to close to headers in fear of heating the oil up too much. Might putting put it in the front where the battery was it will hang down slightly in the front wheel well area but than weight on the front end, And thought about putting it in the trunk but don,t know if its too long of a run for stock LS-7 pump?
Old 04-14-2016, 06:17 PM
Originally Posted by grendel View Post
I think you're over thinking this.
That would be a first!!! LOL
I'm hungry for some Salt Lick.....
Old 04-14-2016, 06:19 PM
Bryan -- talked to Sutton today -- he told me to tell you to go dry sump.
Old 04-14-2016, 10:14 PM
carbuff's Avatar
carbuff carbuff is offline
Sigh...
I had written up a long description of how I made my decision and all of the work I was planning to do, and then I get an email reply from the engine builder regarding my oil pump selection. I had talked myself into a wet-sump solution, likely using a worked-over pump from Schumann. I read good reviews and talked with them on the phone about their pumps. But my builder (Halston) tells me his experience with the pump wasn't so positive. Great...
TOW is heading his way tomorrow. It will help to have another set of eyes looking at the car with me and discussing what I should do. I'll have more info soon.
In the meantime, I did make one purchase today targeted at helping with this problem. I decided to replace my PRC radiator with a unit from C&R Racing with integrated PS and oil coolers. I am going to have to replace my current radiator anyway as it is leaking (getting worse), so I decided to step up to a better unit. I will remove a good bit of plumbing and the current 2 coolers mounted in front of the AC condenser. That removes several additional AN fittings and lengths of hose. I will also remove the oil thermostat regardless of the wet vs dry sump solution. That cleans up yet another restriction in the system. Finally, I'm going to remove the second small oil filter which I am currently using from the system. I had decided on all of those if I were staying with the wet-sump, as they would remove a lot of plumbing and restrictions to the oil flow in the current setup... They just naturally go away with the dry sump solution...
More to come...
Old 04-14-2016, 10:16 PM
carbuff's Avatar
I love you guys...
Old 04-14-2016, 10:26 PM
carbuff's Avatar
My current favorite. It's about 1 mile from where I live. An offshoot of one of the Lockhart places.
Old 04-15-2016, 07:39 PM
68LS1's Avatar
68LS1 68LS1 is offline
That reminds me a need another visit to Austin
Would have been keen for Formula 1 this year but is son's 21st that week
Roger
68 RS Camaro Convertible LS1 6 speed
72 C10 SWB Stepside, old skool 350 4L60e
71 K5 Blazer 350sbc T350
