Old 02-04-2016, 06:08 AM
rickpaw rickpaw is offline
Originally Posted by dontlifttoshift View Post
I have another set of LS mounts for the alumaframe if you want to cut stuff up and try it......cheap.
What are you using for manifolds/headers?
Right now planning to use the stock manifolds, but will have to see if they fit.
Tu Ho
67 Firebird (aka "Money Pit")-5.3/4l60e, restomod.
https://lateral-g.net/forums/showthread.php4?t=43170
Old 02-04-2016, 01:25 PM
n77nxc's Avatar
n77nxc n77nxc is offline
Nice work Tu...just not sure about the Ford blue on the Chevy engine. Don't be surprised if it peels off.
1967 Camaro - Project "Resale Red" - Sold to 175RGR
Old 02-04-2016, 08:16 PM
glassman's Avatar
glassman glassman is offline
Looks great Tu...
If you buy the nice high dollar Billet Specialties valve covers, they come with an oval, you can put a blue ford oval on it and 90% of the people wont know the difference.
I'm doing it on my Camaro, just to eff with people....
Mike
Old 02-04-2016, 08:44 PM
Looks great Tu...
Thanks guys. Right now the engine/trans are in and at 3* angle, but there is no room to run the cooler lines. Looks like I have to cut out the trans hump on the pass side and add a bulge to it for the lines to clear. I'll do that after fab up a crossmember for the trans. Right now it's supported by a floor jack.
Holley makes a nice coil cover set up. I may talk the car owner into buying it and paint it blue, with a Ford decal stuck to it.
Hopefully I can get the crossmember fabed up in a week or so.
Tu Ho
Old 04-16-2016, 10:55 PM
jeff71 jeff71 is online now
Any updates?
Old 04-21-2016, 09:44 AM
Originally Posted by jeff71 View Post
Any updates?
I will have updates and new pictures posted in the next few days. Just been busy with life.
Thanks for checking in.
Tu Ho
Old 06-21-2016, 08:25 PM
Hows the Stang coming along?
Old 07-05-2016, 11:32 PM
Rickpaw I sent you a PM
Old 07-29-2016, 11:58 AM
It's been awhile since I updated this thread.
Had the engine in and try to work out the exhaust manifold set up. Tried the stock truck manifolds, and that did not work. The manifolds stuck out too far, and hitting the steering shaft. Finally rolled the dice on a set of Holley cast iron manifolds, and it fit.
Driver side, clears the steering shaft by at least 0.5".
IMG_1377
IMG_1378
Also I lowered the engine/trans as much as I can in order to minimize the tunnel work. Had to enlarge the steering shaft cut out on the driver side engine mounting bracket.
IMG_1250
Tu Ho
Old 07-29-2016, 12:06 PM
I made the trans mount, similar to DSE type mounts, and reuse the stock trans crossmember. I may tie the mounting tabs to the frame rails for added strengths. Right now, there are reinforcing plates inside the pass compartment that the tabs welded onto.
IMG_1294
IMG_1295
Also, converted the PCV to the LS6 style set up.
IMG_1376
Tu Ho
