Old 09-11-2013, 07:54 PM
Rick D's Avatar
Rick D Rick D is offline
Yes I've used the Fuser products in the past, they are nice work very well. The only thing is for what you are trying to do the flexible may still move to much as it is flexible. Fuser also has a rigid foam that will do the same as the 3m product. If you unsure do a test first on a junk part? Stop by a body shop and ask them if they a an old trunk or hood you can have to play with, then try both products in the inner and see which one will give the most support?
Rick
Old 09-11-2013, 08:52 PM
aany001's Avatar
aany001 aany001 is offline
Rick I spoke with my supplier and yes he does carry the 3M panel bond so I ordered it and gonna try it on a test mule. Guys thanks for all the help!! Getting close to paint and Im stressed right out!!!!!!!
Old 09-11-2013, 09:44 PM
Sales@Dutchboys's Avatar
Let us know how you make out. I've seen that same issue with the aftermarket decklids. Like Rick said for the 1st gens an original one is ideal..
The 3M Panel bond would help. It would be best I you could remove the skin and grind all surfaces down to bare metal and re install the skin onto the inner structure.
Like I said let us know how you do and feel free to give me a ring. Do you still have my number?
dutchboyshotrods.com
269-823-2967
Old 09-11-2013, 09:54 PM
aany001's Avatar
Ya Paul PM your digits.
Steve
Old 07-20-2014, 09:56 PM
aany001's Avatar
I know its been awhile but just an update on my trunk lid. I drilled the lip with 1/8 drill bit and plug welded then added the rigid pillar foam and bingo shes nice now!!!!! Trunk lid feels real nice and sturdy!! Thanks guys for all the help!
Old 07-21-2014, 10:56 AM
Musclerodz's Avatar
I uses a spot welder on them in 4-6 places. Takes care of any flexing once I get it where I want it.
Mike Redpath
Musclerodz & Customz
facebook page
Old 08-17-2014, 02:22 AM
frankv11's Avatar
frankv11 frankv11 is offline
Dummy question
Any pictures on where exactly this 1/8 wholes / spot welds are located.
Old 08-17-2014, 08:13 PM
aany001's Avatar
The welds are on the very edge of the inner trunk lid lip. Its where the outer skin meets the inner structure. I hope this helps.
