Originally Posted by T_Raven
I just noticed you have 2 axle styles.
For the full floater style, are those black caps with the set screws and o-rings holding the axle and fluid it?
Is there any reason to run one style of axle over the other?
You are correct T_Raven. The billet aluminum
Hub Cap Seal pictured in all of the Hybrid Floater Kits does in fact retain the
full float style axle as well as seals any diff fluid from escaping.
Both axles ultimately act/perform the same. Some folks may prefer GM/OEM type design/technology, while others may prefer a more traditional style full floater axle.
The full float style axle is more cost effective so may be the deciding factor for most..
Great question and thanks for asking.
Jay
