OK, so get to the point right?! What I'm actually doing to the car in Phase 1.
This is the current powertrain/front suspension parts list. I'm sure I'm forgetting some stuff. I'm sure I'll get some "ugh" responses to some of this stuff.
- LS2
- T101A
- McLeod Hydraulic Clutch kit for 1st gen F-body
- SPC upper control arms and Global West lowers
- Ride tech musle bar
- Wilwood 6 Piston front brake kit
- CCW 17x10 front 17x11 rear wheels
- Hedman/Musclerod stepped headers
- Dirty dingo sliding motor mounts
- QA1 semi-coil over front spring/shock
- Ride Tech TruTurn
On the bodywork side, this is what's either been done or coming down the pipe (need to finish the front so I can turn the car around and start on the rear - wait, that didn't sound right?!)
- Stock replacement subframe blased and powered coated
- stock inner fenders (minor modifications) blasted and powder coated
- rust bucket / bondo filled orignal front fenders replaced
- firewall cleaned an repainted
- trans tunnel modified for T101A shifter
- trunk floor replaced
- Mini tubs (75-25% to do it or not)
- new fuel tank with in tank pump for the LS
- Replicate the '67 rear wheel openings to cover the rear tires without being overtly flared and without doing full quarter stretch
- Inboard rear shock mounts
Again, I'm sure there's a buttload of stuff I'm forgetting but that's sort of the overriding list of things for this phase of the project.
I'm likely going to do a Fay's watts link in the rear as well. But still sort of sniffing around on that. The car also already has bolt in subframe connectors, a 12 bolt rear with Tom's KA axles and rear GM style single piston discs.
As you'll see in some of the photos, I wanted to use a Unisteer rack conversion (given to me by my buddy with the LS2) but ultimately wasn't happy with it. I'm not going to complain or bag on the company because I never went to them directly to try to remedy what I didn't like (since I didn't get it from them) and ulitmately, I'm actually overall happier with using stock style power steering, given the overall drivability goal.
At the end of Phase 1, I want a car that I can turn the igintion key and drive to work, to the store, to lunch... Expectations regarding comfort and "drivability" would be equivelent to my recently departed '87 C30 dually or my '95 F350 PSD. So I'm shooting for "effective" not "perfect".
