Old 07-30-2013, 03:46 PM
bentfab's Avatar
bentfab bentfab is offline
for the props!
Things are looking good
Mark
Follow us on Instagram = @bentcustom
www.bentcustomandperformance.com
Old 07-30-2013, 03:58 PM
cjfirstgen's Avatar
cjfirstgen cjfirstgen is offline
Originally Posted by compos mentis View Post
Were you able to get the info you needed?
Other than just cut some custom spacers for limiting the rack and pinion turn limits not really.
Project "Mercury Rising" '69 Camaro : https://lateral-g.net/forums/showthread.php4?t=41460
Old 07-30-2013, 04:08 PM
fleetus macmullitz's Avatar
I'll send you a pm shortly.
The artist formerly known as ‘cosmo mentis’…
Old 08-01-2013, 10:47 PM
cjfirstgen's Avatar
Some mock up pics
Decided to paint the frame instead of spotting in the paint after some welding some bulkheads to clean up brake lines, etc. ...after all powder coating does make great primer. Had a number of blems too.
Old 10-22-2013, 09:08 PM
cjfirstgen's Avatar
Progress update: frame painted, SS brake line w/ hidden bulkheads underneath frame, 1" sway bar, double adj shocks rebuilt and more.
Now for some addtl firewall mockup for clearance.
Old 10-22-2013, 09:34 PM
Che70velle's Avatar
That looks absolutely terrific! Is the 572 stock internally?
I'd wager that the car will scoot...
Thanks Dad!!
Old 10-22-2013, 09:37 PM
syborg tt's Avatar
That 572 looks amazing
marty-mj
Old 10-22-2013, 09:46 PM
cjfirstgen's Avatar
It is stock internally. The Hogan's fuel injection system bumps it to 700hp. Fun car for sure.
Thanks for the comments!
Old 10-22-2013, 09:53 PM
cjfirstgen's Avatar
Couple other custom pieces making their way onto the firewall. The RestoMod Air bulkhead and steering column will match on the firewall with the bulkhead recessed 3/16" in the custom stamping completed by Dan from Holohan's Hot Rod Shop.
And then the CF Hydrodipped inner fender brackets so they blend in with the real CF Anvil inner fenders. Them being black just stood out too much.
Old 10-22-2013, 10:13 PM
coolwelder62's Avatar
Wow!!!!!!! The project is turning out amazing!!!!.Love the Holohan Part's.
