Originally Posted by waynieZ
I remember back in 2008 I read there was a bolt hole in the AutoKraft LS oil pan that wasn't drilled and tapped in the LS block. Is it still that way or does the block have the hole drilled and tapped on the newer blocks?
I'm not sure what you are referring to. I installed an AutoKraft (champ makes it) pan on an LS3 block and all the holes lined up perfectly. The pick up tube wasn't perfect and had to be modded slightly to get the proper height as well as fit the main cap that it bolts to.
