That sounds like something a girl would say.... That's not a "problem" - that's just an item that could be easily rectified with a bit of hot rodding... You know - like taking some stuff apart and adding whatever is needed! LOL
Thanks I know all about taking things apart and putting it back together my way! Lol
So to update I pulled the trigger and ordered a Monster can fromhttp://www.rxperformanceproducts.com RX Performance. Tom and Tracy are great guys to work with and came up with a kit specifically for my application. They also have a clean sideswipe raptor that goes in place of the oil fill cap on the valve cover and my valve covers being from Holley they are making one that will screw into the Holley style hole. I will continue as soon as the kit arrives.
I have the same setup as you and I have attached an image on what I had done -- I have since switched to a Holley Dominator ECU and don't have the MAF but with the roots style blower I didn't have to relocate any of my lines, I also ended up running a -8 for the clean side separator.
The tank works great! good choice.
Raj
_________________________
- Raj
'69 Camaro - Current Project
