Old 04-12-2014, 09:05 AM
ataves1's Avatar
ataves1 ataves1 is offline
Originally Posted by Roger Poirier View Post
Remember you get what you pay for at a body shop. Price seems about right for a decent job. I have spent a lot more than that for my own black paint job.
Thanks for that. Usually when I tell people what I paid they think I am nuts or insist I was screwed royally. The paint is almost perfect, and I got what I wanted so overall I am happy. The shop is going to pick the car up one more time to fix a couple things and do a final buffing. They are definitely a stand up bunch of guys. I went and bought a $100.00 can of wax that came in a jewelry box, and I cant wait to give it a coat. I'm an idiot.
Your car is one of the nicest I have ever seen.
Old 11-26-2014, 09:34 AM
ataves1's Avatar
Default Alignment
Winter is back in MN, so I figured I should update. The car was a handful on the first couple shake down runs. Mainly due to the eyeballed alignment. Bought a Longacre caster/camber gauge and set up a string box. Upper control arms are stock and in the factory position. Used ProForged tall upper ball joints, CPP 2" drop spindles, RideTech Tru-Turn, and QA1 coilovers. It took a lot of shims and are pretty much maxed out on header to control arm clearance. Specs are as follows:
RF LF
Caster 3.2 3.4
Camber 1.2 1.4
Total Toe 0.0
Old 11-26-2014, 09:49 AM
ataves1's Avatar
Default New Wheels!
Upgraded to a new 18" wheel and tire setup. 18x9.5 and 18x11 NewGen Concave Lites with 275 and 315 BFG Rivals. The wheels are super nice, I bought the good aluminum wheel fit tool to make sure they would fit. They are close but good.
Old 11-26-2014, 11:20 AM
Boss 5.0's Avatar
Boss 5.0 Boss 5.0 is offline
Your car looks great. Not usually a fan of the mini lights, but yours are different enough that I like them.
As to the 14k for what got done, that number seems right to me. Stripping it to bare metal and going up to that perfect black finish takes time and skill to do. You were not taken advantage of at all. Fair price for a great job.
Copper Hill Rod & Custom
1955 Chevy BelAir
1951 Chevy 3100
1987 Chevy R10
Glenn
Old 11-26-2014, 11:34 AM
tubbed69's Avatar
tubbed69 tubbed69 is offline
Your car really turned out very nice,wheels look good
Old 11-26-2014, 05:58 PM
ArisESQ ArisESQ is offline
Looks awesome!! Love the new wheels!
Old 11-27-2014, 06:33 AM
69x22's Avatar
69x22 69x22 is offline
Awesome! Love the wheels, and yeah you get what you pay for when it comes to paint. No such thing as a $3000 dollar paint job, unless you do it yourself.
1952 Ford F1 817 HP 8-71 Supercharged 502
1957 Chevy 454LSX
1969 Camaro 830 RWHP ProCharged LS 416
https://lateral-g.net/forums/show...ighlight=yenko
https://lateral-g.net/forums/showthread.php4?t=34171
Old 11-27-2014, 08:48 AM
ataves1's Avatar
Thanks for the input and liking the car!
Old 12-17-2014, 03:20 AM
ataves1's Avatar
Default Roll Bar Install
Just installed a 4 point roll bar from Wild Rides Racecars. The tubes come fish mouthed which is a nice feature. It wasn't built to comply with any particular sanctioning body, just pro touring. This was definitely something I wish I would have done before the car was painted and assembled.
First step after gutting the inside was to locate the main hoop on the rocker boxes. I then drilled 2" holes so I could drop the hoop in and mark the height and angle of the down tubes.
Next I made the 6"x6" plates conform to the rocker boxes. I scored them with a grinder, then bent and welded them up.
Old 12-17-2014, 03:38 AM
ataves1's Avatar
I put the base plates in with Clekos and adjusted the fit of the main hoop.
The base plates in the trunk took a little more work to conform to the drop offs, but were done in the same manner, score, bend, and weld.
I painted the majority of the roll bar prior to final installation with Rustoleum Hammered Black and a small foam roller.
The entire interior was covered with red rosen paper and aluminum foil for protection.
I first tacked the rear down bars to the main hoop, then pulled the front base plates out and dropped the main hoop into the rocker boxes. This allowed me the room to weld all the way around the tubes
