Old 02-23-2011, 03:42 PM
randy randy is offline
Default icemanrd19 67 camaro
Well about 3 or 4 months ago i bought a 1967 Camaro from a guy in fort worth. Well Replacing a few nuts and bolts led me to ripping alot of the car apart. Currently the car is sitting apart and im trying to figure out what direction i want to take it.
I need some help with the steps of fixing this car up the way i want it. I stopped last month bc i felt like i was probably going to do things to the car that i would end up having to take back off so in essence wasting my time.
Exterior
2002 plymouth prowler orange
Marquez billet taillights P/N 103-bc
DSE selecta - speed wiper kit P/N 121001 wired into stock fuse box
Ringbrothers black air frame 20679-1032 hood hinges
Stock hood latch painted black
Forgeline rims 18x9.5 and 18x11 polished outers titanium smoked centers, Fronts 28.58 offset, hub 70.3, rears 25.4 offfset and 70.3 hub
315/30/18 and 275/35/18 michelin ps2 tires
Dse mini tubbed
Dse subframe connectors
Ridetech billet gas cap
RS lower valance with new lights tinted black
Stock 68 camaro mirrors mr-27 and mr-26. First hole is drilled 1 inch up and 8 inches back on the door
68 camaro rs kit with Retro - Electro PN-002 RS Electronic Headlight kit
New rear quarters, trunk, tailpan, hood, roof, floor, dash, and radiator support
New door handle kit part # dw-60p
New rear bumper
Smoothed firewall
aluminum hood strikers
Suspension and Brakes
2012 corvette z06 6 piston calipers with 6 puck pads and 4 piston rear calipers with stock rotors
Kore 3 rear parking brake kit1988-1995 corvette rear ebrake cables ac delco part number 19143763
67 camaro big block intermediate cable pbk-11r
front cable pbk-10a, New e-brake, Drill out the kore 3 bracket to 9/16"
Hydroboost unit with wilwood Master cylinder street quality P/N 2021-STP
Dse front subframe P/N 032006
Dse rear quadralink P/n DS-041703 with ridetech single adjustable shocks
ford 9" moser custom alloy 31 spline axle shafts torino flanged OD 6.9 or less/ press on bearings
1/2"-20x 3.00" studs press in GM 5 of 4 3/4 bolt circle, 1/2" pinion offset
"f" measurement 25.375?""g" measurement 24.375" Total axle width 54/750 axle flange to axle flange
moser 9" ford complete 3rd member Truetrack 31 spline Diff n-case daytona aluminum pinion support 1250 yoke w/u-bolt 4.11 gear ratio
Wilwood proportioning valve 260-11179, wilwood master cylinder and hydroboost
Chassisworks tunel kit P/N 5922-f10
Dse aluminum body bushings
Interior
Eddie motorsports black steering wheel launch MS140-54BK
Morris Classic concepts 3 point setbelts
American autowire kit
Dynalined and Dynamat entire metal part of the car
Rear sony 6x9s using the speaker covers as a spacer
Kick panels with speakers
New stock 67 dome light
New stock 67 rearview mirror
69 camaro rear quarter outer felts with the flag
TMI one piece suede headliner
recaro seats with suede middle inserts
County prison white shift knob P/N sk502-cpbk-6rur on a Finch 6" shifter P/N 7000461-n
Vintage air unit with modified DSE vintage air bracket P/N 011006
dw-20 door mechanisms
cpt-07p fisher logo sill plates
bm-1048 quarter glass vertical moldings
dw-27 window cranks
ws-09 u-jamb seats
gb-16 glove box door bumper set
rsp-11bk black mesh package tray
DJ-100 windsock end caps
vaporworx fuel tank with notched corners with 2012 camaro fuel pump
T56 reverse lockout from wire barn t56-CON
Billet specialties 77109 overflow tank
PRC dual pass radiator 211001 and spal fan setup
ls3 480hp rated at 495 with hotcam
t56 magnum/ ls7 clutch
Afco dynatech 2.5 exhaust 793-91125
Holley black fuel rails p?n 534-209
Finch performance gas/diff dual vent system
Kwik Performance P/N k10143 air conditioner bracket kit
autocraft oil pan
Corvette accessories 19257325
Elite Engineering Catch can CC-200B
PCM of NC p-150028 A/C fan speed bump circuit and PCM of NC Hi/Lo speed Fan Kit
DSE battery relocation kit
stainless works headers part number ca679wd 1.75 primaries and 3" slip fit collectors
dse motor mounts 060401
ws-18 cowl hood to vent seal
ws-47 cowl vent wedges
Part # ws-05 trunk weatherstrip
Part # ws-19 67 OEM window felt set
lic-15 license plate bumper set
Old 02-23-2011, 03:51 PM
THis is exactly how i want my 67
THis was my old project but ive grown up now to bigger meaner toys
Old 02-23-2011, 04:06 PM
KPC67's Avatar
KPC67 KPC67 is offline
Nice Car
My opinion is to keep it driving. I would start with the mini tubs, and rear suspension (my choice is DSE) Then put back on the road. Keep upgrading it as you go.
My personal experience is that my car has been in the shop stripped right down, I am not able to drive it because I cannot afford to do everything I want to do all at once.
Just my .02
Kevin Carter
Old 02-23-2011, 04:12 PM
well in order for me to drive it again i need to rewire the entire car. I dont feel like ripping all the wiring out and doing it all over again. Thats my dilemma. Plus i need to smooth the firewall out and in order to do that ill probably have to pull the motor.
Old 02-23-2011, 05:07 PM
nvr2fst nvr2fst is offline
[QUOTE=randy;334398]THis is exactly how i want my 67 Then you should have bought a 69 Sorry but I had to, after u posted the photo of a 69. Youll be in good hands around here and many will give you helpful advise.
Old 02-26-2011, 12:02 AM
Can i get some opinions about the G link setup with mini tubs? I understand dse is suppose to be the best but how does it compare to G link and price wise?
Old 02-26-2011, 01:03 AM
youthpastor's Avatar
youthpastor youthpastor is offline
cool project!
there are lots of options for suspension and subframes out there. I've learned so much from the Lat-G gang.
I am a big fan of DSE, Art Morrison and I really like dealing with the Speedtech boys.
enjoy the process
[SIGPIC][/SIGPIC]
CHRIS HOLSTROM CONCEPTS
http://chrisholstromconcepts.com/
Old 03-01-2011, 07:32 PM
what should i expect to pay for a quality 4 link and rear end setup? Should i go with the 12 bolt gm or 9" ford? why one over the other? sorry im a newb when it comes to this type of stuff
Old 03-24-2011, 06:10 PM
Old 03-24-2011, 06:11 PM
Originally Posted by icemanrld19 View Post
Some update photos
