Old 07-12-2017, 06:55 PM
Default Petal stop for hydraulic clutch
Useing a late model F body clutch master and stock petal set... Anyone have any pics of what the made for Stop? To keep you from bottoming out every time you press clutch
Old 07-21-2017, 12:17 PM
andrewb70's Avatar
Weld a nut to the pedal and use a screw in furniture adjuster.
Andrew
Old 07-21-2017, 01:32 PM
BBPanel BBPanel is online now
Name:  IMG_0545 - Copy.jpg
Old 07-23-2017, 10:56 PM
Tuske427's Avatar
Tuske427 Tuske427 is offline
I made a bracket with an adjustment screw and jam nut on the pedal assembly. Works great
Long Live the Muscle Car
https://lateral-g.net/forums/showthread.php4?t=26338
Instagram: @tuske427
Old 07-30-2017, 04:51 PM
Dr G's Avatar
Dr G Dr G is offline
Another option to using a pedal stop is to modify the pedal arm so that the pedal pad rests closer to the floor. This reduces clutch pedal travel but also makes the clutch easier to modulate.
I designed on of these pedals for my own BMW 325i Wagon in 2002 and used to sell them for other BMW's in a prior life. But the same principal will work on any car with a clutch pedal.
http://www.bimmerworld.com/BMW-Inter...Series-07.html
Old 07-30-2017, 06:40 PM
kevin_l's Avatar
kevin_l kevin_l is offline
Here's mine, its adjustable and simply bolts to the firewall. Also incorporated a 02 f body safety switch.
Old 07-31-2017, 06:34 AM
rickpaw rickpaw is offline
Can you elaborate on how you incorporated an 02 safety switch ?
Thanks.
Tu Ho
Old 07-31-2017, 12:54 PM
kevin_l's Avatar
@ rickpaw
This pic should show how I attached the switch mount. I got the switch tab from the donor car but one could be made fairly easily.
It's a simple open/close switch. Plan is to just wire it inline with the starter solenoid. Testing with a meter it gets a closed signal very early while depressing the plunger. So hopefully I can fine tune the pedal stop without having to move the switch.
Old 08-02-2017, 10:55 AM
Thanks Kevin.
Tu Ho
