Go Back   Lateral-g Forums > Vendor Specific Technical Discussions and Support > Speedtech Performance USA
Old 06-10-2016, 03:27 PM
Ben@SpeedTech's Avatar
Ben@SpeedTech Ben@SpeedTech is offline
Default Speedtech's new 3rd Gen Camaro suspension
We're developing a new suspension for 3rd gen Camaros, click here for more!
-Ben, Creative Director
Old 06-11-2016, 12:40 PM
Ron Sutton's Avatar
Hey Guys & Gals,
Just chiming in to let everyone know this new 3rd gen F-Body clip has the same optimum geometry & set-up I designed for all of the Speedtech front clips & full chassis. Although each front suspension was optimized for the application, this one is very similar to the 1st & 2nd gen clips.
Video for RSRT Designed Speedtech eXtreme Subframes & Chassis
To watch this In-Depth Video on YouTube ... Click HERE.
New Speedtech eXtreme Front Subframe & Suspension Package
New Cutting Edge Design Includes:
  • Ron Sutton Race Technology geometry built-in.
  • Strong Box type laser cut and jig welded construction - reduced weight over factory subframe.
  • Special subframe width & shape allowing 315 front tires.
  • Next-Gen ATS 7075 Forged Aluminum Spindles.
  • High-Ackerman steering arms for ATS spindles.
  • C7 heavy duty bearings & hubs.
  • Speedtech high clearance upper & lower tubular control arms
  • Upper control arms feature additional caster adjustability.
  • Control arms powder coated gloss black and fully assembled with Delrin bushings.
  • 3-piece Speedway Engineering sway bar – Choice of rates from 400# to 1300#
  • Sweet racing DUAL POWER rack & pinion steering.
  • Accepts LSX engines with Speedtech fabricated oil pan and motor mounts.
  • Adjustable engine frame stands allows 3/4" fore & aft range.
  • Fully adjustable rear cross member fits all GM transmissions as well as T-56 and TKO.
  • Factory alignment holes offer ease of aligning frame to body and bumpers.
  • Mounting hardware, instructions, and custom alignment specs.
  • Comes bare. Powder coat options available.
  • Built-in tow/tie down hooks eliminate strapping around painted frames.
  • Ridetech single adjustable coil-over shocks, including delrin thrust washers & adjusting wrench.
  • Hypercoil coil-over springs – Wide choice of rates.
Available as Bolt-In Clips for:
67-69 GM F-Bodies Camaros & Firebirds
70-81 GM F-Bodies Camaros & Firebirds/Trans Ams
68-74 GM X-Bodies Novas, Venturas, Skylark & other GM X-Body Cars
and now ... 82-92 3rd gen F-Bodies: Camaros & Firebirds
OPTIONS:
• Powder Coat Subframe – Flat Black
• Powder Coat Subframe – Semi-Gloss Black
• Powder Coat Subframe – Gloss Black
• Powder Coat Subframe – Gun Metal Grey
• Powder Coat Subframe – Silver
• Billet Aluminum Body Mount Set
• Engine Bay Round Tube Chassis Down Bar Supports
• Double Joint Steering Shaft Kit
• LSx Engine Adapter Plates
• Speedtech 1 7/8" LSx Headers, Mill Finish
• Speedtech LSx 1 7/8" Headers, Show Polished Finish
• Ron Sutton Tailored Suspension Tech Service #40STP
• Ron Sutton Tailored Brake Tech Service #29
• Ron Sutton Secret Sauce Digressive Track-Star Valving added to Ridetech Single Adj Shocks
• Ridetech Triple Adj Shocks w/Digressive Track-Star Valving
• JRI Shocks w/Digressive Track-Star Valving in Single, double or triple adjustable
For more information ... OR To Place Your Order ... Contact Ron Sutton Race Technology:
Phone: (916) 834-8051
Email: [email protected]
Address: 11374 Amalgam Way, Suite K, Gold River, CA 95670
Website: www.RonSuttonRaceTechnology.com
