Go Back   Lateral-g Forums > Technical Discussions > Safety Equipment
Old 09-14-2014, 07:54 PM
renegade6 renegade6 is offline
Default 3 Point seat belt upper mount
I need some ideas on where to mount the upper portion for my three point seat belts. I am thinking along the B pillar (#2 in picture) but, it isn't as well reinforced as newer cars the same issue goes for #1; it's not reinforced very well. I could put it on the lower point (#3) and it would be much easier to reinforce but, I'm a little concerned that it would be too low. I'm open for suggestions.
Thanks
63 Biscayne
Schwartz Performance Chassis
Build thread: https://lateral-g.net/forums/showthread.php4?t=37302
Old 09-14-2014, 08:11 PM
ADiCarlo ADiCarlo is offline
Is this for daily use or track use?
By the position of the number I assume it's for the front seat. Do you have a design in mind?
Old 09-14-2014, 08:13 PM
Sieg's Avatar
Sieg Sieg is offline
My two cents.....
You might also go to the Schroth website and check their technical page on mounting. It may give you some ideas.
Old 09-14-2014, 08:44 PM
Mostly daily use with some track time. I have some ideas for building the reinforcement plate, just need to pin down the location for it.
I have thought about putting a harness bar in it and running Corbeau retractable harness belts.
63 Biscayne
