Originally Posted by DT69Cam
No, No, I'm referring to the spacer that is attached to the transmission that the bracket is attached to. The part that attaches the bracket to the trans. In the pic it looks octagonal, almost like a rod coupling. Is there a bolt screwed into it to secure the bracket ???
Oh I see what you mean now. I just bent up a shift lever like B&M send with the shifter but I made it taller so I could bend it out of the way.
The hole I drilled is the only one I need at that end, the others are for different trans. I guess I will try to make the hole that goes over the gear range selector. I think they use hardened metal I dropped theirs and it has a sharp ring to it.
I need better tool than a jig saw and file.
If you see any top secret stuff in the background ignore it I took these without my glasses....
